TwinTurbo.NET: Nissan 300ZX forum - Have the injectors tested or test them yourself, or swap in
ZaXxon
on September 01, 2013 at 5:34 AM
O2 sensor issues, car running rich all the time. Need advice
posted by Woody75 (Denver)
on August 30, 2013 at 11:35 PM
a known good set.
Woody75 (Denver)
23:35:02 08/30/13
Coolant temp sensor?..
Cjw3
01:04:52 08/31/13
seems to be working fine.
Woody75 (Denver)
07:42:40 08/31/13
Tim, I found that the ECU open loop operation is based on
DVDBURN (MD)
09:47:51 08/31/13
That's a nice little tid bit to file away.. Thanks (n/m)
Cjw3
09:54:02 08/31/13
To be more accurate in that first statement...
DVDBURN (MD)
10:24:45 08/31/13
Thaks for the info.
Woody75 (Denver)
11:04:44 08/31/13
Sounds like a stuck injector to me... (n/m)
ChaseGrayTT
18:36:25 08/31/13
Hey Woody!
ChaseGrayTT
07:25:40 08/31/13
cas is good. everything is firing and reading right.
Woody75 (Denver)
07:46:16 08/31/13
dont the o2 reads .34 if unplugged?
toykoz32
12:02:08 08/31/13
Most ECUs are usually .32 without O2 feedback but I have...
DVDBURN (MD)
19:48:01 08/31/13
Check with wide band O2 sensor
jerdobi
18:47:18 08/31/13
k value is correct
Woody75 (Denver)
19:14:41 08/31/13
Something's not right with the o2 sensor circuit. Those
Evan_Wright (Ca)
00:41:35 09/01/13
Have the injectors tested or test them yourself, or swap in -
ZaXxon
05:34:12 09/01/13
